Minn Kota works in reverse only
flomonte
I have a Riptide model RT4.3B that I think is a '97 model. It worked fine until yesterday. I discovered that the ground battery cable broke and the Positive wire was corroded and broken at the connection on top of the motor. I repaired both of these connections and now the motor will only go in reverse and not forward. It would be OK if it only went forward. Any Ideas?
