Minn Kota V2 Power Drive 45 problem
solar7
Hello all:
I have a MK PD V2 45, bought new in 2010, which also has a Power Drive module for use with the control fob. The boat its on is a 15 foot Lowe console model; one battery at the stern is for starting the outboard motor, and one is dedicated to the trolling motor, and the trolling motor battery was new last year. The boat was wired at the factory for a trolling motor, and there is an outlet at the bow end for that purpose. So, last week, I charged up both batteries to full charge, and the night before heading out, I did the usual full-boat systems check to make sure all was in order. I plugged in the trolling motor, heard the beep to indicate it was getting power, and I turned it on and it ran. The next morning, when I plugged it in, no power. The battery status light will not show a thing either. Later at home, I checked the battery: full charge. When I bought the MK last year, I got the MK plug and receptacle kit, and it worked great all through 2010. So, I took the plug apart and re-assembled to make sure all contacts were good, but no result. When I bought the unit, the dealer/authorized service center said there was no need for the in-line fuse since its only a 45 lb thrust motor (in-line fuse is apparently recommended for the larger 65 lb thrust motors). Under the console, I can't really tell where the fuse relay for the factory-wired trolling motor would be, so I changed out three 5A fuses to be safe. No luck.
So, any ideas?
Many thanks,
Chris
John_S
Re: Minn Kota V2 Power Drive 45 problem
Look for the fuse/breaker near the trolling motor battery. It should be within a foot of the positive terminal.
PS: Fuse/breakers are to protect the wires, not the unit. I would not have much faith in that dealer.
Silvertip
Honorary Supreme Mariner
A 45# thrust motor draws close to 40 amps at maximum draw. 40 amps is a lot of power and makes a great arc welder if a short occurs between the battery and the motor. That is why you ALWAYS install a fuse or breaker at the head end of any electrical circuit. You need to check for voltage at the receptacle. If there is none, then go back to the battery. You lost a connection somewhere.
solar7
Thanks for the replies gents. I also checked the receptacle, all wiring there seems in order, and I hooked the trolling motor to another battery just to be sure; nothing.
I was going to take the trolling motor in to the service center and see if it runs when they plug it in there; if it does, then I know its a circuit somewhere on my boat. I'll also take this time to put an in-line fuse in near the battery as suggested.
Any other ideas or suggestions, let me know.
Many thanks all,
Chris
solar7
I thought of this too, but the MK receptacle is an odd-looking three-pronged beast. Any idea how to test the receptacle?
solar7
It was a wiring problem after all, motor is fine. I have installed a new 40 A inline fuse on the trolling motor now. The boat's about 10 years old, and the other in-line fuses are the glass-tube type, which I replaced with a blade-type fuse, easier I find to change on the swells.
Good advice from the folks here, many thanks.
Chris
