minn kota v2 foot control mystery
georgeoverly
Hello,I just bought a boat with a MK v2 trolling moter.IT has a handheld remote that works great in all functions.
I hooked up the foot pedal and it runs the prop but won't turn left or right .It is the same connection as the remote(which works).
I have used a cont. tester on the wires and have cont. on all pins and no shorts.
Have tried jumping and was getting the prop to turn .I then tried jumping black and yellow and black and green?,(the wires going to contact switches).NO luck.So what I would like to know is ;
Is black the common ground?
Why would the remote work and not the pedal if both use same connecter and cont. test on foot wires checks out?
Is there any reason the wiring would be differnt for the 2 controllers?
If I jumped the wrong wires for L & R movment,please tell me which ones to use.
I havent taken the board out yet but it doesnt look like there is alot to it,Am I missing something that I cant see yet?
Please Help
Thank You
Silvertip
Honorary Supreme Mariner
Re: minn kota v2 foot control mystery
Continuity tests are meaningless unless you know what you are testing. Obviously if the Fob works and pedal doesn't something is wrong in the pedal. The pedal has a membrane style circuit board in it. The speed control is a variable resistance slider. All other functions (Left, Right, Go, MOM/CONT) are switch functions. Those folks who tend to beat up Minnkota foot pedals tend to do an elephant pounce on the pedal which tends to rupture the membrane which then allows moisture into the contact layer and that leads to failure.
sschefer
If the Powerdrive has the autopilot and remote installed the foot pedal only partially works. The Terrova is the only model that will work with both simultaneously.
If you remove the side panel and disconnect the remote module the foot pedal will work again.
georgeoverly
THANK YOU.The wires for the foot control were disconected,after unpluging auto pilot and pluging foot wires in it worked great.Is there any reason I should not connect both set of wires,seeing as only one controller (remote or foot) can be hooked up at a time? Agian thank you,you just saved me a boatload of money and time!!!
I wanted to hook up both controllers inside the motor housing ie the 3 whites together and the 3 blacks together,that way I could use either controller I wanted (both controllers connect to the same plug going to motor,so it would be impossible to use both at same time,you have to unplug one to use the other).I called Minn Kota and thier tech support said that if I did there was a chance that one could feedback to the other.I don,t see how if only one could be connected at a time.
I will hold off for now but would really like to hear what anyone who has the same set up or knowledge of it thinks. I am also considering the possibility of installing a double throw-double push switch(not sure if my discription of switch term is right) But I think you know what I'm thinking.
Please chime in and help me out if you can.
