Minn Kota rt50s no forward motion
upperdown
I just bought this motor for 20.00 because it had no forward speeds. I took it apart and everything looks fine, no obvious electrical damage. I got the parts break down with a wring diagram and it doesnt match how the motor is wired but the heat shrink on the terminals appears to be untouched. I'm going to call Minn Kota today but don't expect much form them. Reverse works like a champ. Any thoughts would be appreciated.
Variable speed, 2001 model. On the inside it has a date of 02/2001 on one of the components so the 2001 wiring diagram was the one I was using. Are these like cars? manufactured in 2001 but sold as a 2002 model? Wiring diagram might be different.
Silvertip
Honorary Supreme Mariner
Re: Minn Kota rt50s no forward motion
Since the motor works fine in reverse but not forward I suspect the FWD/REV switch is bad. Since trollers don't use reverse much, one could simply swap the two leads going down the shaft to the motor. Therefore when reverse is selected, the motor is actually running forward. But, checking the switch with an ohm meter would be a logical first step.
upperdown
I went ahead and moved the wires to correspond with the wiring diagram and VOILA! Runs like a champ. They guy I bought it from must have "fixed" it to the point where it would run in reverse only but never looked at a wiring diagram. Best $20 I ever spent, except that one time in Amsterdam.
