"Minn Kota power drive" trolling motor nowmakes groaning noise and has no more power?
Hi all,
My Minn Kota Power Drive trolling motor suddenly stopped working properly after working flawlessly for several years. The propeller now turns only up to about the# 3 setting, higher than that, the motor emits a groaning noise and the prop does not turn. It was functional & fine right up to then. When at the lowest settings, if I apply pressure with my hand to the hub of the prop (simulating water pressure on the blades) the prop stops and again the groaning noise- basically has no torque or propelling power. Battery bank is fully charged, shear pin intact. Any one have any ideas what is wrong? how difficult would it be to fix for someone who is mechanically pretty handy (can replace my outboard water pump, take apart & rebuild carb, etc. )
Any advice is greatly appreciated.
Thank you
JP
Hi all,
Thank you
JP
