MINN KOTA EP-96 trolling motor problem
lhw
Does anybody have a power tilt relay for a ep96 twin elect.trolling motors? The part # 995-4575.Is there any other way I can get this to work without this relay? I would sure appreciate any help anyone can give me ,
Thanks Larry
Re: MINN KOTA EP-96 trolling motor problem
It would be really odd if MinnKota used a special relay. By that I mean relays may have differently shaped bodies but electrically, they are nothing special. Check the relay you have for a Manufacturers name other than MinnKota because they very likely didn't make it -- some relay manufacturing company did. If that number is all you have and you know the relay is bad, you can try to open the housing and check the internal structure. Any electronics supply firm would very likely be able to match it. If you don't know how to do that, go to Radio Shack and ask for help or if you have a friend that is an electrical engineer or anyone familiar with relays (like you heating and
A/C repair dude) as them to help you. You cannot run the motor without the relay. Relays are used when a small current is used to switch a much larger current. Besides, without a schematic we have no idea what form factor relay is needed.
