JohnnyLowe16
Thread starter- Joined
- Jun 12, 2012
- 1
Need some advice. Firstly let me say I hate this trolling motor, but it came with the boat ten years ago and it isn't in my budget for a new one. I cant seem to coordinate my foot to steer. I am foot dyslexic or something...I prefer hand tiller...
However, the trolling motor has ran fine for 9 seasons and it has been taken care of and up until now has got me where I wanted to be without complaining about my inability to steer with my foot and hitting logs.:facepalm:
Last three trips out, it cuts off intermitently on speed 5, less so on speed 4 to 1. Basically it starts then cuts off and starts again. It seems to work better if turning left or right, but is a real issue when pulling the boat straight ahead.
Battery is new, connections all were verified to the quick disconnect at the bow. Pigtail and connector are verifed with meter in ohms and volts. 60 ckt breaker does not trip. I did not check amps under load cause I didn't have my meter out fishing with me.
Cleaned all the connections in the pedal to the switches, speed rheostat and mom/off/ con swithch and verified they were working with ohm meter.
Motor runs fine out of water, so seems to be a load issue. Prop off and no windup on the shaft, shaft spins smooth, and no signs of corrosion. So that leaves brushes, armature and or magnets. I tried to rebuild a 35lb tiller type a long time ago and got my armature bent from magnetic ejection.......bad story....for later...
I have no idea how much it should cost for a service center to look this over and repair. Anyone have experience with this could give me an idea as to save for a new trolling motor or get it repaired would be nice.
To get this off the boat is going to be a pain, the guy who originally installed it put it on and the ground down he bolt heads so no one could steal it......slotting them with a dremel doesn't sound like fun to me, might need to smoke them off.
