Minn Kota 765MKX fuse size?
raptor1958
Purchased a used boat this spring that has a Minn Kota 765MKX trolling motor installed.
Looking at the positive line fuse holder and it has had some heat damage. A 30A fuse was Installed.
Is a 30A fuse the correct size? If not what would be the proper size?
Thanks
Brian
Al-53
Re: Minn Kota 765MKX fuse size?
I would use the trolling motor breaker instead of a fuse.....they come in 50 amp are resetable....they are quick blow also....so if u have a problem it will trip right away...and u can reset them.....you can find them on ebay at a good price....Minn kota makes one and and also a few other companies....but make sure its thermal and resetable
Al
JB
What Al said. I have used both a 40A fuse and a 50A breaker with a 765MX. Much prefer the breaker.
raptor1958
Thanks - I will check into these.
Brian
