Minn Kota 50AT
soonersorlaters
I have a 12V - 50AT TM that quit today- Noticed the in-line fuse had melted- 1st time over the years this has happened.
I am running 10 gauge wire from battery to motor. I cannot remember the fuse size I had.
Need to know if I should re-run 6 or 8 gauge wire and what size fuse I will need.
Of course , I do not have the owners manual and can't find it anywhere on-line.
Any info is appreciated.
Steve
Silvertip
Honorary Supreme Mariner
Re: Minn Kota 50AT
You need a 50 amp fuse or a 50 amp circuit breaker. Depending on the distance between the motor and battery you might get by with 10 gauge but 8 gauge is probably in order.
