Minn Kota 50 lb thrust trolling motor problem
bkcameron
I bought one of these thirty days ago to help troll our pontoon out of shallow water and it has ceased turning. I have check the fuse and the battery is good. Has anyone had a problem with the motor on these?
NYBo
Re: Minn Kota 50 lb thrust trolling motor problem
Welcome to iboats!:cool:
Take off the prop and check for fishing line wrapped around the shaft.
Silvertip
Honorary Supreme Mariner
You have checked the fuse -- how? The battery is good -- how did you prove that? Did you check the connections. "Looking" is not a check.
Dave Turner
If not the fishing line you coulld have a bad gasket and water could get in. If the water gets in there for some time it will corrode the insides and it will not turn. I had one that i had to clean up and put new brushes and gaskets in to get it back on the water. I think someone must have dumped mine in the lake???
bkcameron
I checked the fuse on the battery. I ended up taking it to the closest service center, so we will see what comes of it. Thank you
bkcameron
Funny thing. One morning, it was turning, as if someone turned it on at night. I wonder if someone tampered with it.
