Re: Minimum battery capacity for 50TLDI
Let me try this one last time. Direct Injection outboards, regardless of brand, require a battery with a higher CCA rating than you would find on an engine in comparable hp that is not a Direct Injection outboard. The fuel injection system requires a minimum amount of current that many of the old, standard 70 amp marine batteries are not able to deliver. It's just that simple. And no, you cannot start a direct injection engine, regardless of brand without a battery. In theory, you may be able to start a direction injection with a battery that has less than a full charge, but I wouldn't bet my life on it. While that is certainly not a plus to the design, I really don't think it's much of a drawback either. There are a variety of features and benefits on engines that may cost you something else. Direct Injection is just the next improvement over traditional 2-cycle outboards. It's not perfect. It's just more reliable, more fuel efficient, easy starting, has a smoother idle, less vibration, quiet, weighs less than 4-stks, has better hole shot, does not smoke and hey, lets not forget, should cost less to maintain and repair. Of course when you weigh all of that against it's inability to start with a dead battery........Maybe two batteries in a boat would be a solution? Naw, no one has ever done anthing as radical as that.<br /><br />P.S. Tohatsu does not want consumers tinkering with or troubleshooting TLDI engines. They really are too complicated for the average consumer to self adjust/repair. They put a 3 + 1 year warranty on TLDI engines so that you will feel all safe and snug. Have a little faith in what they say you need to have to operate it.
