Minimal power 50hp johnny
mark83
Hi guys
Was hoping someone could help please...i have a 50hp johhny 2000 model and took the boat out for a run after finally getting the motor running and was fine getting on plane but on the way back i had very minimal drive like 3-4knots max and the outboard wasnt revving high at all...i went to idle and it revved high as expected and got good response but as soon its in gear Fwd or rev just couldnt get the revs up...thought it could be the props clutch but wouldnt the motor stil rev high and no drive like a slipping clutch in a car??
Also when at home i put it in gear and revved high as expected...only when in the water it struggles...what ever that means
Any info would be much appreciated
Mark
oldboat1
What did you do in the way of repairs or maintenance, and what were you trying to fix before it finally ran for you?
jakedaawg
Model # may help someone help you, I believe they had 2 and 4 strokes in '00. Model # can be found on the transom clamp, J50?????. Although Racer is most likely right in this case.
