don't laugh, first time posting to ANY forum...
i started up my 1980 15 hp Evinrude and while it was running in gear i noticed a milky beige fluid being sprayed off the blades of the prop. on closer inspection it appears to be coming out from behind the prop, only when it spins. not if it sits idle. I drained the gear case and that fluid was nice and black no water at all. is this beige stuff leftover oil from combustion? could it be leaking out of the gear case? into the prop shaft/exhaust area?
