A.Hoj
- May 24, 2006
- 39
Been having some power issues and after searching though posts and inspecting the plugs I figured I had water in the cylinders. Well I took the head cover off and sure enough all 3 were all full of milky oil. The head gasket was in bad shape, but the metal rings looked ok still. I celaned up the head cover real good, smothed it out on emery cloth and then checked it with a staight edge and feel gauge and it is not warped. Got a new Gasket today and put it on, re-tourqed everything properly, ran it for a while, and when I checked the plugs they were milky still, ARGH! So Should I assume that it is probably coming thought the exhaust gaskets? I don't want to take this apart and have replace the gaskets on that too unless it's the next logical step. I've included some pictures from when I took the head cover off. Also does anyone have a source online to get those exhaust gaskets?
Thanks!
Thanks!
