Milkshake within minutes. Engine Block pressure test good.
2003lsr
Pull the intake manifold. It is quite possible the underside of it is cracked. Michigan Motorz sells a new one for that motor at a very reasonable price.
w2wlake2lake
Thanks for everyone's help. Looks like a false alarm. I changed the oil and then ran a quart of diesel with another oil change and seems I'm good. I'm not sure what the original problem was but everything checks out now. I do have a question about the intake manifold. Is it 11 foot pounds or 35? The book I have says 35 on one page and 11 on another but I broke a bolt at 35. 11 seems low but when I removed it the first time they didn't seem very tight.
HT32BSX115
Glad you don't have a cracked block etc!
It is 11 ft-lbs.
I was going to post a copy of the page right out of the manual, but I think thre might be a copyright issue.........
It would be worth getting yourself a Mercury manual. They're not all that expensive.
Cheers,
Rick
w2wlake2lake
Ok thanks. Just double checking. I have them at 11 f/p. Seems to be running great but I still need to check the timing. I had changed the intake manifold and didnt have the mark for the distributor. I think I have it pretty close. Any one know whats the timing procedure for a 4.3l merc i think its a thunderbolt iv. maybe V. Do I have to ground a wire out to put it in base timing mode if its a IV? I can only find procedure for a V. Im guessing if I cant find the purple/white wire I have a IV and no Base timing mode is required.
alldodge
TB-IV doesn't have a base timing mode, just point and adjust
