mike45
mike45
changed impeller, manual recomended shift rod be 21 27/32 inches from upper surface of lower unit, it measured 21 1/4 inch and I moved it up 1/4 inch to 21 1/2 inches , when put back together wont shift into reverse, any suggestions on this problem. (1995 115 Evinrude crossflow powerhead)
Joe Reeves
Re: mike45
Measurement is to be taken in NEUTRAL and to be from the top surface of the lower unit to the CENTER of the shift rod hole.
I don't have the 1995 115hp manual at my finger tips so I don't know the exact measurement BUT if you measured in any other manner than mentioned above, therein lies your problem.
mike45
Re: mike45
thanks, I dont recall if i had it in nuetral, I turned the shift rod 4-5 turns to left to raise it 1/4 inch, is it possible to turn shift rod without dropping lower unit, putting back bolt with pin was a real job.
kenmyfam
Re: mike45
Drop the lower unit. Put it back to where it was if it was good previously.
