Mid-section removal 87 johnson
Nicklund
Can't get rubber mount out how? Any body ever changed these out..87 Johnson 140v4 lower unit is off
boobie
There should be a metal portion in the center of that mount. Drill two holes through it and tap them out to 1/2" std thread. Then take two long I/2" bolts and thread them through them until they hit the exhaust housing. Keep on going and you will pull the mount right out. Or I've seen guys burn them out with an oxy/acy torch.
Nicklund
Thank u so much..You can place the year can you..I know it's a 140 Johnson v4 the boat is a 87..I think it's a 87 but 88 could be..No markings can't find d away to get my model..I know it's the looper with 4 one barrel carbs
boobie
Look for a core plug about the size of a quarter on the block. Post any # 's you find on it.
