Mid 90's Ocean Runner 150 Alarm & Fuel problem
mhathaway
I have an early to mid 90's Ocean Runner 150. Has been running well all summer until this weekend. After about 30 minutes of use the motor started to rev down like it was not getting fuel. This happened at 3/4 throttle. If I throttled back quickly it would stay running and I could rev it up and down in neutral. If I left it at 3/4 throttle it would come all the way down on its own and stall. After sometime restarting and trying to run it an alarm buzzer started coming from the throttle control box while the engine was running. It was not a constant buzz but pulsing like an alarm clock. I would shut it off and then could restart it with no buzzer but it would only run a little bit before dropping rpm and then buzzer sometimes but not alway comes back before it stalls. Fuel bulb was always limp after it stalled. It was about 1/3 full oil in the reservoir. The bulb on the oil line was hard. I filled the reservoir for the heck of it but no change. Usual amount of "smoke" behind engine at idle. Water was running out and engine did not seem at all heated. We run non ethanol gas and probably used about 20 gallons since last fill (40gallon tank). Filter replaced last year. Any suggestions? Thanks in advance. Mike.
jakedaawg
The buzzer is the "no oil" alarm. Cease running engine.
From now on til this is cleared up any running/testing must be done with 50:1 pre-mix.
!st step on this is a compression test. You just had a no oil alarm and this step is a must.
Chris1956
Honorary Supreme Mariner
Your motor likely has 4 alarms. They are no oil (at motor), low oil (in reservoir), overheat and Check Engine (fuel restriction).
Overheat will put the motor into SLOW mode. Fuel restriction can cause the motor to stall, which sounds like what you are seeing. I would recommend you check main strainer under airbox for debris, and clean/replace any other filters or separators you have. The antisiphon valve in the fuel tank pickup tube could be clogged as well.
mhathaway
Thanks for the reply. Two questions:
1- Does the oil injection system need to be disabled when running the pre-mix?
2- Do you think the engine loosing power and stalling can be caused by no oil or is it another issue?
Chris1956
Motor can and shuld be run on a 50::1 premix, when you suspect the oiler system is malfunctioning. If the oiling system is working the motor will run at 25::1 and smoke a bit more, which is not an issue.
I do not think your loss of power is due to an oil injection issue. I think it is overheat or inadequate gasoline flow.
jakedaawg
No to 1, yes to 2
Need comp test results first, then start wondering....
jakedaawg
The no oil alarm does initiate slow mode. That could be the power loss. I did not see Chris had replied.
I will stay out. A model # would help determine whether you have the system check giages and lights or the 4 tone horn system.
Chris1956
The oil alarm does not initiate SLOW mode, which is why I think it is an overheat or fuel restriction issue. If it was really a no oil issue, the motor would not slow down, but likely seize.
A year or model number would certainly help us diagnose
Joe Reeves
(VRO Horn Warnings)
(J. Reeves)
NOTE: I retired around 1991/92. Possibly some of the later V4 engines and others may also incorporate a fuel vacuum switch that would enable a fuel restriction warning to sound as mentioned below, an unknown factor to myself.
1 - A steady constant beep = Engine Overheating - The V/6 engines, some others, have a "Fuel Restriction Warning" which is also a steady constant beep.
2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
NOTE - If the warning horn is the black plastic (overpriced) three wire type horn, the warning horn should beep once when the ignition key is turned to the ON position. If it does not, it is either faulty or someone has disconnected it (a stupid move!). At any rate, if it does not beep which indicates that the horn is non functional, find out why and do not run the engine until the problem is corrected.
Chris1956
OK, that model appears to have the 4 alarms. I would first check the mainstrainer under the airbox for debris, clean replace any other filters/separators and then check the antisiphon valve for restrictions.
Then I would check the motor for overheat causing the SLOW mode to be engaged.
mhathaway
Ok. I assume by airbox you mean the big cover/filter that goes over the carburetors? (not much of a mechanic if you haven't already guessed ; ) ) I am not sure where the mainstrainer is. Inside the box?
Thanks again for your help Chris.
Chris1956
Under the black airbox, you should see a white knurled knob. It will have a screen and a seal. Clean the screen and make sure the seals are in place, before tightening the knob.
