Mid 80's Merc 4.5 outboard - no idle
Idahofos
I just bought a mid 1980 merc 4.5 hp outboard. Would not start initially, Carb & choke cleaner. Now starts, runs reasonably well at anything above idle on through top end. Drop down to idle & it dies. Any suggestions? I can't seem to find any mixture screws, etc.<br />Thanks ahead of time.<br />Brian
JB
Re: Mid 80's Merc 4.5 outboard - no idle
Howdy, Idahofos.<br /><br />Was your test in the water or on the hose?<br /><br />You may have a clogged low speed jet, or you may simply be off on link 'n' synch.<br /><br />I would overhaul the carb and do a careful linkage and synchronization adjustment, using the factory manual.<br /><br />Good luck. :)
Idahofos
JB,<br />Thanks for the reply. I did the run up in a large barrel filled w/ water. I will p/u a manual and do the carb. <br />Regards,<br />Brian
