MG Trolling Motor Problem
basstrackin
I have a 45# thursut MG trolling motor that when ran on speed 5 will cut in and out byt works fine in al other aspects..any ideas..Rob
John_S
Re: MG Trolling Motor Problem
Welcome to iBoats.
We will need to know some additional info. The more detail, the better.
A few examples off the bat:
Bad connections.
If transom mount with aligator clips, could be bad "bite" on the posts.
If wired with an auto-reset breaker, could be tripping out on too high of current or defective breaker.
Silvertip
Honorary Supreme Mariner
More than likely the breaker is too small for the high current load on the fastest speed. You might also want to remove the prop and check for fish line wrapped around the shaft which can cut the seal allowing water inside. That then causes the motor to "bind". Turn the prop by hand. It will feel jerky but it should turn relatively freely. If it turns fairly hard the bearings have tightened up.
