Swalker3368
- May 10, 2022
- 9
I just purchased a fix me up. Have a 1990 mercury 135 black max. Starting dueling issues. Have it tore down to reed valves as research led me there. Once I got to it, the reeds I suspected were bad. Question is. In all the build up of oil in the bottom were a bunch of metal shavings. Any idea what they are from?
Before taring it down did compression test cold and 5/6 were at 87, one was zero. Engine was cold when tested as won’t stay running.
Should I replace reeds rebuild and test or continue on as I am this far in?
