Mercury XR2 150, Need help once again!!!
flipsider
Ok took the power head off and the lower part. I need to find the parts number for a wear sleave and a sealing ring, I have looked but im not having any luck finding them. Also what all gaskets do I need to put it back together. The wear sleeve had a crack in it.
flipsider
Re: Mercury XR2 150, Need help once again!!!
Do you have to use the wear sleeve. I know the bearing is perfectly fine.
carholme
flip;
What is your s/n?
Gerry
