Jim Harpold
- Jun 26, 2010
- 8
Problem #1
I have a 1991 135 hp Mercury Black Max 3 carb. The warning horn goes beep beep beep non-stop I had it in the shop for repair and after 5 hours of labor to stop it and $423 cost the beeping stopped but was short lived and started 2 days later. The things checked while in for service was the oil pump sensor which checked OK the oil flow which was in specs, air pressure. The beeping stopped when the tech switched the wires right to left left to right on the switch boxes. This was short lived and started again. Ideas and help needed.
Problem #2
In trying to fix the above I found that gas was coming into the oil line so I changed the check valve and replaces the two clear plastic oil lines before and after the oil pump. Since doing this I have a air gap in the top of the line that runs from the pump to the gas line. I have opened the oil cap on the engine tank while running to let off the air and fill the tank and while the motor was stopped opened the screw on the oil pump to let out the air in the line but the top of the line for 2" has no oil. Is this a problem or not and how do I fix
Problem #2
