Mercury Classic 50
I bought this boat without trim. I purchased a single solenoid 2 cylinder system and bolted it up. It works fine, but... I don't want to drill a hole in my dash and install the old school three button up/trailer/down switch when I have the trim up down on my throttle handle (newer version). There are four wires coming out of my throttle control a blue/ green/ light green (I think faded) and a brown. Blue is up, green is down, I know that. The other two???
Now, the old school button has the trailer mode when you push the center and up buttons and the trim system I installed has the limit switch on the right cylinder. How do I incorporate that into the newer button on my throttle button?
The pump has the three terminal input, blue and green and red. But the red wire is huge (10 or 12 gauge). I can't hook that red wire up to the little wires on the newer version switch. It will burn down for sure. I think I need a relay!!! But how do I incorporate the limit switch into this conversion?
Any help would be great.
