Mercury Tracker 15 HP Fuel/carb issue
gobucs1
I have been having a problem with the float now fuly closing, I fixed the pin and now that is fixed but now the motor starves for fuel. I can see the fuel turn to air in the fule filter as I increase the rpms in neutral.
Any suggestions on what to try?
Motor is a 1998 15MLH Tracker pull start.
Also does anyone know the initial idle setting? I have one turn in my notes but just want to be sure before I reset that and try anything else. Fixed the float problem created or unmasked more unfortunately.
Gas tank has 2+/- gallons of gas, and primer bulb gets firm now meaning float works fine.
Thanks!
gobucs1
Re: Mercury Tracker 15 HP Fuel/carb issue
I can get it to run at high speeds with the choke pulled out now but it dies when i push the choke back in.
Will not idle still with choke pulled or not.
