Mercury to Johnson fuel tank.
carleton
I changed the fitting to the Mercury tank to run my Johnson motor but I can't get it primed.When I squeeze the ball I can here air pushing from the motor end of hose.It is a old tank that I don't know if it is flawed.What can I do to correct this problem?
carleton
Will Bark
Re: Mercury to Johnson fuel tank.
The only thing I can think of is are the arrows on the primer ball pointed to the motor?
carleton
Yes the arrows are right.
Daviet
Sometimes one of the check valves in the primer bulb will stick, try holding the primer bulb in a vertical position, fuel flow towards the sky, and try pumping the primer bulb. Make sure the hose is attached to the engine.
carleton
Now I am ready to get it started.Is there a place I should set the two buttons going to the carb?
Daviet
You are going to have to tell us what engine we are working on, model number?
Daviet
OK, the top one is the low speed needle valve, static setting is 1 1/4 turn out from lightly seated. The bottom one is the high speed needle valve and the static setting is 3/4 turn out from lightly seated. You will have to fine tune both of them with the engine on the boat in the water. Adjust the slow speed needle to get the best idle while under way and then open it another 1/8 turn. With the engine at wide open throttle, adjust for best rpm, and then open it another 1/8 turn. These adjustments have to be made with the boat in the water and not tied to the dock.
carleton
Well now I have to asked what the compression should be on this motor?It doesn't seem to have much.
Daviet
They don't list the specs for compression, but I would think somewhere around 65-75 psi. More important it should be within 10% of each other. Has the engine been sitting for awhile, might have some stuck rings. See if you can get it started and try a decarb on it and see if it helps.
carleton
I don't know the history on the motor but I would guess it has been sitting.Is there a product that can be sprayed in the spark plug holes to free the rings?
Daviet
You can do a decarb using sea-foam, run a search, several posts on it. I don't know if spraying anything through the plug hole will do a complete decarb, guess you could try it.
carleton
.Now it it will rev up full throttle and run wide open for 30 seconds then idle down on its own and stop running.Any ideas what needs to be done?It only runs when the choke is closed almost all the way.
carleton
