I know you've seen this post a million times but I've been through the forums and can't find the answer.
I have a Mercury Thunderbolt 50. It is black with a blue stripe under the mercury logo. I can't use the serial number as it has been worn off over the years as the steering has rubbed it away. The serial plate was on the front of the motor under the steering mechanism. It is also a pull start if this helps.
Thanks in advance.
Thanks in advance.
