mercury switch
clifweb
I have a 1959 35hp evinrude lark and I'm wondering what is the purpose of the mercury switch, I see a diagram that refers to it as a safety switch. Thanks clifweb
F_R
Honorary Supreme Mariner
Re: mercury switch
I believe the 1959 had the dual mercury switch, right? One section keeps you from running the electric starter at high throttle settings, and the other section disables the vacuum cut-out switch at high throttle settings.
"Safety"----yes, if you were to start it in gear, at fast throttle, it would take off and run over the dock......or somebody. That would be a tad unsafe.
HighTrim
Re: mercury switch
I can remember last summer happening upon a family in a boat floating around the lake. The father was desperately trying to start his motor. I believe it was a 58 Lark. He was getting nothing from the key.
Floated around the rear of his boat, and from mine gave the mercury switch a tap with my finger towards horizontal. Motor fired right up.
The kids started yelling that I was a magician, and for the rest of the summer called me the wizard. LOL kids are funny.
I thought the name was cool, my wife thought I was an idiot. She wouldnt call me the wizard.
I have seen starter solenoids replaced needlessly due to the owner thinking it was shot, when in fact the mercury switch was simply bent off horizontal or faulty.
F_R
Re: mercury switch
Yeah, I'd like to own stock in the solenoid factory. Most of them are replaced needlessly. And when they do replace them, they use a car solenoid, which will instantly burn the wire off the mercury switch. Maybe I should buy stock in the switch factory too?
boobie
Re: mercury switch
I sometimes wonder if anybody knows how to check out a solenoid. All it takes is a couple of jumper wires, a 12 volt battery and an ohmmeter. You can do this on or off the mtr.
Chris1956
Re: mercury switch
How could Ole Evinrude have installed a Mercury switch on an Evinrude. It doesn't seem right, somehow.
