Mercury stators failing
elvinpena
Hello
I have owned several mercs over the years. One 1989 black max 135 hp and two 150 2004 saltwater. It's always the same; stators just fail regularly among other electrical components like trigger etc.
My questions are:
1 How can I help diminish stator failure , if I can ?
2 Why are many suppliers out of stock for stators of merc 2004 150hp ?
3 Why Merc stators fail so much ?
[/IMG]
westexasrepublic
Re: Mercury stators failing
running with failed rectifiers can stress stators till failure. rectifiers fail when the outboard is connected or disconnected improperly, like causing sparks and reverse polarity hookup...
I agree check both rectifiers/regulators and inquire about the red stator upgrade. You can check the Voltage output to the batteries, should not be more than 16 volts and switch your meter to A/C and put on batt posts, if you see more than .25 A/C volts the diode clusters are bad and the rect/reg need replacing.
rodbolt
in two words.
motorola electronics.
yes keeping battery cables clean and tight helps the rectifier/regulator issues some.
has nothing to do with high or low speed charge coil burnouts.
triggers typically break the wires, thats why most jap stuff went to fixed trigger coils and used the ECU to alter timing.
Faztbullet
My questions are:
(1)...(A) Make sure battery wing nuts are removed and S/S locknuts replace them, bad grounds kill VR's (B) if you have a battery switch make sure its a "make before break" style as switching while running can damage VR's (C) remove any onboard charger from starting battery (D) use correct CC and AMP battery
(2) That stator drives CDM modules and less prone to fail, they still fail but not like the old encapulated stators. Its only offered as a OEM item or R&R item thru CDI Electronics thus no aftermarket replacement...
(3) CDI tech says: breaks in stator windings/varnish, bad connections, defective/bad/failing batterys, rectifier failures can dump one or both legs of the stator to ground thus turning it into a heating element(remember its AC voltage) overheating stator windings(including high/low speed windings as frame is what is heating) causing stator failure. I replaced only 2 of the newer "bobbin" style stators in the last couple of 3 years....
elvinpena
Thanks to all.
I will be following your advice !!
