imported_Voyager
Thread starter- Joined
- Feb 8, 2007
- 36
I have a 1982 50hp "M50", in-line 4 cylinder. New water pump (impeller and entire pump housing replaced), rebuilt carbs. After I did ignition repairs (new trigger), I took the motor to a local (well-trusted) expert to set the timing and idle mixture.
The motor is running great, and peeing strong, but after about 15 minutes from initially starting up (cold) and then some hard running (pulling a tube) it will begin to lose power. Throttling back to 4k rpms and just running along it does fine. I noticed that it is "peeing" steam when warmed up and running at 4k. Returning to lower rpm it pees warm water. Working it hard after warm-up, the power loss occurs much more quickly, just a few minutes.
The tube from the cooling water port on the block to the pee-pee nipple is clear. Could there be an obstruction in the cooling passages?
The mechanic suggested replacing the (cheap) fuel line, so I got a new bulb and bought the "real metal" fitting for the engine end of the fuel line. The engine usually needs a few squeezes to get fuel for starting up, even if warm. Is there a way to test the fuel line? The tank end fitting is from Wal-Mart, could that be an issue?
Any thoughts on what to check next would be appreciated. Thanx in advance.
