bobbuffalo43
Thread starter- Joined
- Jun 7, 2003
- 11
Help! I bought a used Ranger bass boat as a winter project. The engine, a 1996 Mercury 150 EFI (0G3xxxxx) was in pretty rough shape as it had overheated badly and melted a lot of parts. I started out with the engine running roughly and no telltale water from the p-hole, and the engine would overheat (with no alarm) and I would then shut it down. I replaced the alarm buzzer, the over-temp sensor and the water pump (although the old pump looked like new). No positive results and no water from the p-hole. I did a compression test and the number five cylinder was about 25 pounds below the other five cylinders. I replaced the bad head gasket on the starboard side (it was leaking into the water jacket) and the compression on all 6 cylinders was then between 112 and 119 pounds. The condition of the cylinder bores on the starboard side was excellent thankfully. I replaced both thermostats which were frozen shut and would not open in boiling water. I checked the pop-off valve which was OK. As of today, when I start the engine it will idle smoothly for a few minutes with no water coming out of the telltale hole. After a few minutes water would come weakly out of the telltale hole, the thermostats would open and a lot of steam would then come out of the propeller exhaust. The engine did not overheat but the water pressure gauge on the dash read zero with an occasional flicker of 1 to 2 pounds. When I disconnected the hose to the water pressure gauge (at the top of the block) very little water sputtered out. The gauge read fine when air pressure was applied to the end of the hose. I’m at wits end as to what the problem could be. I’m thinking of something around the exhaust divider plate? Can anybody out there give me some ideas? Thanks in advance for your help!
