i have a 40hp 3 cyl. 1998 with only 3 seasons on a pontoon. had very little pee so i changed the pump and thermostat, now when i start the motor i have to rev-up for 30 seconds to get the pump going or the temp gauge goes up fast. it will stay at about 140 degrees if im moving but when stopped and start up again i have to rev-up again to get the pump going. its almost like it looses its prime, it never stops coming out the pee hole. the motor only has about 75 hours on it and only about 25 hours on this pump. i was told to maybe put another pump in, is this the answer? i have put pumps in other motors with good results, but this one has not worked right at all. NEED HELP THANKS jwn
