Mercury Ignitionn Wiring
I bought a new mercury wiring harness to run from my bppat to my mercontrol. I need help matching the colors of the wires to the letter on the ignnition swithch it belongs.
The color Wires I have are as follws
Red
Black
Yellow
Gray
Orange
Purple
Brown
The ignition terminals read
s
c
a
m
b
and the is another M but it is a differnt type teminal
I would appreciate any kind of help. I can provide pitures if it wold help.
Thanks,
Randy
Chris1956
Re: Mercury Ignitionn Wiring
S is for solenoid. Connect the small yellow wire.
A is for accessory that is purple.
Grey is tach signal
Black is ground, usually connected to oner of th M terminals
Orange may be the ignition killer on your motor. Check it out, and if so , connect to the other M terminal
I am not sure what C is. Check the switch with an ohmmeter to see what it connects when it is turned to start and run. You need a terminal for the red wire (unfused +12VDC).
BTW these are guesses since you haven't provided year or model.
my year model mercury motor is a 1975 time froma i can provide the serial number if that would help.
THANKS
I bought a 2007 Mercury 90 H/P 4 stroke motor. I had a 1998 150 H/P Mercury previous. Is the wiring harness and such the same. I have a new harness aswell but no diagram for the wires. Any and all help would be greatly appreciated. Trying to get a last day in on the water. Thanks again!
