This 90 HP Mercury 78 Thunderbolt 6 cyl in line came separated from the boat.<br />The timing is off. The spark plugs are non gap type.<br />The pointer is a wire. the wire aligns to TDC when cylinder is at top nearest the plug<br />TDC is at the wire, and the distributor pulley to cyl # 1.<br />Compression is 115 to 120 PSI.<br />It cranks but no fire. at end of cranking like a pop.<br />Carburators were rebuilt.<br />The book says to set the distributor pulley in line to the dot in the flywheel. There are three that look like balancing marks. At .640 there is also a dot on flywheel. On top of the flywheel also there is like an arrow mark. <br />Can any wizard outhere can help me dcipher this enigma? Mixture screw set at 2 turns.<br />
