Mercury Ignition Switch will not turn
fabsafe
Switch is press to choke type, built into mercontrol...will not turn, even after healthy injection of WD-30 type lube...Sugested fix please....
Is replacement switch the only cure? - thanx - Fred
Laddies
Banned
Re: Mercury Ignition Switch will not turn
If your using the right key, then you will have to replace the switch.
