Mercury Force 50 HP, Starter?
ronhud
I am having problems with starting my Force 50 HP. The problem is that when I turn the key, the engine only turns over one time. If I keep turning the key over and over one time, it will eventually start. It sounds like a dead battery. I installed a new 850 CCA battery and polished/cleaned all cables. I just don't feel comfortable when I am on the water trying to start a motor that only grunts. I can turn the flywheel by hand, so the motor is OK, I think. When it starts it runs OK. Would a new starter make this motor spin?
Barnacle_Bill
Re: Mercury Force 50 HP, Starter?
Sounds like the contacts inside the starter solenoid are burnt. You can verify this by jumping the 2 big wires on it.
jerryjerry05
Do a compression/spark test.Then check all the contacts and rebuild the starter/J
ronhud
Got it fixed now. Was a bad starter. Worked great when out of the circuiit, but on line it was not powerful enough to turn the motor.
Hi, im having a similar problem. Starts great cold. Run it for a little. Turn off. Then it wont restart until tomorrow. Good battery. No overheating alarm. I think that when it gets hot, some connections in solenoid may not be hitting.
how can i 'jump the 2 big cables?'
what does this mean?
Thank you for your time.
