dohcdelsol93
Thread starter- Joined
- Jul 13, 2010
- 97
have a mercury blackmax 150. I belive it's about an 88.
compression 120-130 on all cylinders cold.
new thermostats
Physicaly inspected head gaskets when stats were changed.
inspected water pump and looked in great shape.
runs great with ear muffs/idle
as soon as i give it gas in gear it will run a few min (3-5) then over heat quickly.
The pee turns to steam. Up until it gets hot the pee stream is steady and good.
I'm thinking exhaust divider gasket is gone and letting hot gas pass into the cooling ports.
Second question reguarding this, will a leaky exhaust divider gasket cause the engine to run like crap? It will idle fine and when in netural it will rev but when in gear it wants to die when put under load. I just cleaned all carbs (no varnish/trash in them but cleaned them anyway) New fuel lines, drained/flushed entire fuel system, 93oct fresh non ehtanol fuel in it. All plugs are clean and getting good spark on all cylinders.
new thermostats
