I fired up my outboard for the first time this year and it idled rough and stalled when given some throttle. I took the carb apart and did a thorough cleaning. The idle is now smooth but it still stalls/hesitates when given some throttle. There's a little plunger on the carb attached to the throttle that injects a stream a fuel when given some throttle to prevent stalling. The plunger is also attached to the small primer bulb. When I depress the plunger by manually by hand (the same way the throttle linkage does) the engine doesn't rev up. However, when depress the plunger it does. I believe this is the reason why it stalls when given some gas. Am I on the right track? Thanks in advance!
