Mercury 9.8 110 serial number not showing up in lists
lonestar65
Hi all!
Long time reader first time poster. I recently purchased a 9.8 with a 1965 Lonestar as a winter restoration project. I was able to get it started however it appears the water pump will need to be replaced, I gave it sufficient time to warm up knowing some of these came with thermostats installed. I've looked everywhere under the sun, and Google, trying to identify the year so I can order replacement parts. The (SN: A143401) and I've attached images for reference.
Thanks in advance for the help!
GA_Boater
Howdy and welcome aboard.
Your actual SN is 0A143401. The leading zero is to match the current Merc SN scheme. It's a 1985 model, but year is not important for Mercs as only the SN can be used for parts ordering.
Parts diagrams for your 1985 9.8m, SN 0A143401 are here - https://www.mercruiserparts.com/7-5-5206550-up
The thermostat would be obvious on top of the exhaust cover.---Port side of the motor.-----They had a spring loaded clamp.----Rubber gasket and allowed you to clean the thermostat with just simple tools.
with the cowl off, its extremely obvious if you have a thermostat or not. of the 3 9.8's I had, only one had a thermostat
lonestar65
Thank you so much for the responses! I had not considered dropping the leading 0 in the SN! I will double check when I get home after work but I'm reasonable sure my unit does not have the thermostat. I looked up images of it and it looks like its easy to spot!
