Hello, I'm having cranking issues with my 78 mercury 850. Last week I was running it on water muffs in my yard, adjusting throttle cable and idle stop bolt, and gear shift adjustment, while shifting and revving throttle the muffs came off without me noticing, the engine started squeaking and stopped, would turn over, I pulled plugs and sprayed with wd-40 then got it to turn with ratchet on the flywheel, I did a compression check all 4 was right at 122 except no. 1 was at 112, anyhow when you crank it over it will intermittently freeze up with the squek/squeal noise at times will turn over for 10 seconds and other times only a second or two then gets tight again, then I spin it a couple times with ratchet and it will free up again, I pulled the lower unit and no change. Does anyone have an idea what would cause this, maybe a reed valve or something loose in the crank case? This is my first boat and am not familiar with 2 strokes, I am mechanicly inclined though.
Thanks for your time and opinions or experiences.
