100333624
Thread starter- Joined
- Apr 24, 2012
- 205
I decided I'm going to keep my 80hp instead of upsizing to a 115. I have to take apart the swivel bracket assembly because something in there is loose or broken. I see a big ring sitting on the bottom on the shaft that is loose, or broke off from somewhere and the motor is able to be pushed back and forth by hand, just moving inside the assembly there. I was told this could be a big job just to get access in there, I would have to remove the powerhead, is this true? Is there any way I can get this replaced without butchering the motor? I have the motor already removed and mounted on a stand, any help??
Here you can see that ring just sitting there loose..
