Re: Mercury 75
40MPH is fairly good for your setup,K.<br />But you can improve planing time by adding a stabilzer (like a doelfin) to the cav plate.<br />See a merc dealer about borrowing or renting a higher pitched prop. But if you change the prop pitch, keep an eye on the RPMs to make sure you are getting full RPM with the increase in pitch. If not, you are over-propped, and must revert to the original.
