I have a Mercury 60 hp, serial # 6429362. I went to the lake and it started fine. Parked the truck and it would not. It did not seem to have any fire to the plugs. At home I checked it out and was only getting fire at the plugs on occasion. I found corrosion and bad insulator on the wirs to the stator. I could not replace the wires beyond the corrosion so I replaced the stator. I also found bad wires leading from the switch box to the coils. I now have no spark. I have checked voltage while turning over they are as follows.14v from the stator (Both red & Blue), 3v from all of the wires leading from the trigger to the switch box, NO Voltage coming out of the switch box going to the coils. Is the switch box bad?
