Mercury 50hp still gas leak
theshoaibahmed
  • Hi all master brother
    This morning i went for fishing and noticed when i was starting motor, gas was still leaking and when its not running, gas doest leak. In this forum some one suggested, may be carburetor leaked and they were right lower, carburetor was damaged (cracked) and i use glue and fix it and seems like i am not getting gas leak from carburetor(i think) see the picture brother and please suggest me. Motor is not even starting anymore. Gas is full so
    ​Endup i had to get it towed to launching deck. I want to learn and fix the motor and truly i dont have much to sent it for repair.
    Serial number. 7134221
    Mercury 2 stroke 4 cylinder.
    Mercury outbond 50HP
    Pleaae advise
hl
I'm not sure what type of glue you used. The wrong glue could break lose and clog something in the carb. Try to find a used carb and give it a good cleaning
theshoaibahmed
Thank guya for your help, i initiate and rebuild the carburetor first time in my live and waola... Took me 4 hr to carefully uncover, unscrew and put together, run it and no drop leaking...
Again thanks frienda for your help and puahing people to do what is best for them
