I have a Mecury 50Hp thunderbolt, it starts and idles fine when you set of it will run OK while in a 5 miles per hour speed restriction, when you leave speed restrictions and run it flat out it runs for a few minutes (2-3Mins)then it dies and only runs slowly even when the throtle is full open. If you squeeze the bulb it will rev up again for a short burst and then go back to slow running. When I come in and mess about for a while and go out it does the same again.<br /><br />(When Isqueeze the bulb a jet of petrol comes shouting from a hole in one carb but not the other)<br /><br />Any help would be much appreciated
