Mercury 430HD Rebuild and restore
Mantle
Bought a 2008 Mercury 430HD that needed a little TLC
THE BAD
-Had wear all around the edge of the floor. port side had several spot (about 6 inches each) that has worn completely through.
-The edge of the floorboards had been removed to attach brackets then reinstalled using flush mount rivets. over time the rivets loosened up and started to chafe the floor
-Transom had severe dry rot and had completely separated from the sides of boat. (She is a little over power, with 2004 Yamaha 50 2 stroke bolted on the back :) )
-Trailer Leaf springs are rusted out and no longer supporting weight on one side
Steps to come
-inspect damages (become very very sad and depressed :( )
-remove transom
-patch holes and reinforce floor
-Build new transom
-install transom
-put everything back together and put boat in water :)
-Be happy
Materials used
-37oz/1670 denier PVC: AIRE PVC Raft Floor Material sourced from NRS
-Coosa board Blue
-Clifton Urethane Adhesive (1 pint)
-Westsystems G-Flex 655
-AquaSeal
-Solvents: MEK, Acetone
Mantle
The project begins
Mantle
Inspecting the damage
Mantle
Removing the Transom
Mantle
Repairing hull. Still need to add pictures of the outside repair
Mantle
Building New Transom
used West system Epoxy for fiberglass and G-flex to attach transom to boat
Sea Rider
Congtas Mantle, nice boat along self repairs. Would cost a fortune repairing all those mentioned issues at a inflatable boat shop. The new transom was custom cut from plywood sheets or it's a one piece solid wooden transom ? Is it for a short or long shaft OB ? Maintains the original water release valve on lower transom?
Happy Boating
Mantle
Sea Rider,
Currently set up for a Long shaft OB. For the transom I sandwiched together two sheets of 3/4 Coosa board and to top it off I have a heavy aluminium bracket (will up upload more pictures this week).
I did't want to put anymore holes in my transom as of yet. So I wired in a 12v self priming pump to act as a makeshift bilge pump.
-cheers
