could somebody please tell me what they think the problem might be?????
I have a mercury 25 hp 4 stroke outboard. Only had it out 3 times this year and it was running fine. I have the oil changed every year when I have it winterized along with spark plug replacement.
The last time I had it out, I started it up, and I heard some sort of alarm. I shut it off, started it back up, same thing, about 15 seconds after starting it, some sort of an alarm went off. Checked, had plenty of water discharge. Shut it off, started it again, no alarm. took it out, on the water, went to full throttle, and it bogged down. Could not get it to power up to full throttle. N oticed a sort of knocking noise. Took hood off, checked oil, could barely read it on the stick. Added oil the next day, only took about half a quart. Still, would not power up to full throttle. Will start right up, and idle all day long. Boggs down at full throttle, with a knocking type noise. Also, I notice what seemed to be some sort of a black grease all over the shaft of the motor right under the exhaust. Took it in for repair, explained everything to them....they cleaned carb, charged me $70 to do so, told me it was good to go...... took it out, and still bogs down at full throttle, and still has a knocking type sound to it.
Can you PLEASE help????? I'm begging anybody for some advise!!!
If you can help in any way, I certainly would appreciate it.
The motor is a 2000, I think.
Thanks for your help
