I have an 86 Merc 75hp serial # 6613762 that is running on 3 cylinders, the #2 cylinder is not firing. I checked the plug, coil, plug wire and still cannot get any spark. Upon further checking I found a wire set comming from the stator with a tag that says something about it being for a 3 cylinder. Is this something the factory done or an after market wiring setup? Do I need to get the correct stator wires foir this motor to run on all 4 cylinders?
