timmybuddhadude
- Apr 18, 2014
- 21
Re: mercury 2cylinder 40hp 1997 starts but wont run...need help !!
Gerry !!
So it's okay to see that spark/flame?
If i get a new hose/barb on there the spark flame wont melt the hose or travel down the FP diaphram and cause damage?
You are totally brilliant
So the flame is normal?? It looked a bit freaky to me... the flame comes out....
T
..and how will the 'flame' become a 'spark' with that hose and barb connected properly..the pulse line.wouldnt the same power come out/in
& how does no pulse line effect its performance ...what does it do except for power the FP
I am a bit 'freaked out' at this stage that the flames from hole wont go down and set alight to the fuel pump
I really need you to say no they wont and all is okay to order and attach the barb because if that flame goes down to all of that fuel that won't be good.
Is the barb fitting a one way suck type thing valve because it seems to me the barb fitting goes at the top where the flame is...
if you say its normal..and i just need cooling system..this hose and barb..and then in the end the stop switch I am going to be really happy
Gerry !!
T
