Mercury 25XD old petrol sludge gotten into engine...help..!
PeteB_2000
Hiya,
I got a new engine tonight and the above has happen by the previous owner, he said it still starts ok but when you goto put any power it stalls, was ran with old petrol that had turned into gunge accidently.
Any suggestions for me how to get this working ok or things to check, I havent tried it myself yet or even taken the lid off, Im not a mechanic or even remotely knowledgable but I will give anything a go.
Cheers
Pete
DHPMARINE
Re: Mercury 25XD old petrol sludge gotten into engine...help..!
Obviously you have to dump the gas,clean the tank AND fuel line.Then get fresh gas and oil.Beyond that I suggest you have someone clean the engine lines,filter and rebuild the carb.This is not exactly HARD,but it sounds like you should have it done.
DHP
PeteB_2000
thanks for that, someone today has told me to try adding redex to the gas to help it get rid of the gunk and clean the jets, is this a good idea?
Regards
Pete
tashasdaddy
it is a preventative, not a cure. the only way to get it out is physically, and it sticks to everything, and blocks passages.
PeteB_2000
hiya i had it on the river today and it runs pretty fine on about 3rd
power anymore and it splutters looses power then cuts out, tried spraying some carb cleaner into the throat but no real joy.
Plainsman
DON'T spray carb cleaner into the carb. It needs to be an oil mix. Try a product called Deep Creep that has lube in it or use a premix that you make yourself.
Get the carbs cleaned and get rid of the old gas.
PeteB_2000
ok cheers I think I will try and dismantle it today :^
tashasdaddy
after you do the carbs, do a link & sinc, this puts the electrical and carbs in sinc so the work together properly.
PeteB_2000
how do i make my own premix and what with?
Ive removed the carb and taken it apart it looks fine to me, how should i clean it or should i soak it in something? (remember i dont know what im doing :^ )
PeteB_2000
as above mate im a complete novice so i dont know what you mean by doing a link and sinc , could you expand on it please
Pete
tashasdaddy
pete, get a manual, at 'oldmercs.com' it is a must if you are going to try to do your on maintainance. your engine runs on a 50-1 mix of gas and tcw3 outboard motor oil thats 6 US gallons of gas to 16 US oz of tcw3 oil. this is the premix. just put some of this in a spray or squeeze bottle and inject a little in the carb mouth. never use starting fluid sold in stores, as it has no oil and burn at a much higher temperature, and can ruin your engine in a instant. the link & sinc is a step by step procedure, that is in the manual. seeing you metioned "petrol" you will have to convert the gallons and ounces. as far as the carb it need to be dismantled and soaked overnight in a carb cleaning solution, blowing out with compressed air, and them reassembled with a rebuild kit. good luck.
PeteB_2000
hiya,
ive got a manual, also removed the carb, i understand about making my own solution up now, unclear what to soak the carb in overnight?
Pete
PeteB_2000
oh forgot to mention that I bought some "powertune" today
